I have added a domain and enabled ssl on it.
Example:
domain.com www.domain.com
I want to add another domain as alias. and enable same ssl
domain2.com
www.domain2com
Example:
domain2.com
www.domain2com
Currently you need to disable, then reenable the let’s encrypt checkbox. We will work on a checkbox for a future release.
