Hello, I used the installation creak https://gabizz.github.io/hestiacp-scriptline-generator/ without the DNS panel, I thought I wouldn’t need it, but today I realized that I needed it. I looked at the forum, the Internet, did not find the answer, apparently no one does this). Is it possible to set DNS separately, and how to do it? Thanks
There is currently no modular option to add Hestia components after installation. You can backup your installation, reinstall with the desired components and then restore the backup. It may also be possible for you to read the source code of the installer, and manually preform the required steps.
Yes, this is not very good, I have several services on the same server (. It’s clear, I’ll put it again. Thanks!
Since this has been asked many times before in the forum…
Ok thank you
