good evening, how can I perform a proxy_pass between two Hestia servers, my first server receives public ip, through Nat (10.10.20.100) in my firewall, so far everything is fine, my main domain domain.tld serves correctly, but I have a second server (10.10.20.200) HestiaCP and when performing the proxi_pass the browsers show “too many redirects”, it should be mentioned that I have a third server on 10.10.20.150 that only has LAMP and works perfectly with having modified the tpl and stpl, then I show code in location /
.tpl
server {
listen %ip%:%proxy_port%;
location / {
return 301 https://%domain_idn%/;
location /error/ {
and .stpl
server {
listen %ip%:%proxy_ssl_port% ssl http2;
ssl_certificate %ssl_pem%;
#ssl_stapling on;
#ssl_stapling_verify on;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
location / {
proxy_pass http://10.10.20.150;
#Proxy Headers
proxy_redirect off;
proxy_set_header Host $host;
#Proxy timeouts
as I mentioned this code works perfect for me for LAMP(10.10.20.150), but for the second HestiaCP(10.10.20.200) server, it gives me the error “too many redirects” What ngixs directive am I missing?
I mention that they are two different files, proxy_lamp and proxy_second_HestiaCP .tpl and .stpl
