How to remove php 8.3?
Hello. Just installed the panel. Installed a configuration with multi php. After installation there is no way to remove version 8.3; it is not in the list. But it works on the server. How to remove it?
Ashampoo_Snap_28 декабря 2023 г.16h48m40s_001
v-delete-web-php 8.3 in command line
THANK YOU VERY MUCH!!!
