How to Stop HestiaCP from Automatically Rebuilding Website Configuration?
Suggest me Hello HestiaCP Community,
I am facing an issue with HestiaCP where the website/domain configuration appears to be getting automatically rebuilt or regenerated.
I want to disable the automatic rebuild process because I have made some manual changes to the web server/domain configuration, and HestiaCP is overwriting those changes during an automatic rebuild.
Server Details
  • HestiaCP: Latest version
  • OS: Ubuntu/Linux
  • Web Server: Nginx
  • PHP: Multiple PHP versions
  • Server Type: VPS
Hi @divyaagrawal7795
You can’t avoid the rebuilds, but in your case, you should create a custom template with the modifications specific to your site and assign that template to your web domain. That way, the next time your site is rebuilt, you won’t lose your changes.
