Wibol
August 19, 2019, 10:51am
#1
For two times, just after:
Install Debian 9 on Hetznet VPS.
ssh [email protected]
“apt update” and “apt upgrade”
wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh
bash hst-install.sh
exit
v-add-letsencrypt-host
I get the next error message:
Error: Let’s Encrypt acc registration failed
Error: domain ssh host.domain.tld does not have an SSL certificate.
Doing it from GUI the message is the same. I have tried to generate a LE certificate for “host.domain.tld” marking “Enable automatic HTTP-to-HTTPS redirection” and/or “Enable HTTP Strict Transport Security (HSTS)” but don’t works. I used “Rebuild All” too.
I can visit https://host.domain.tld:8083 and http://host.domain.tld (:80), but not https://host.domain.tld (:443). Probably this is the problem. Creating a new web (test.domain.tld) the problem continues.
I have installed HestiaCP more times and never happened this.
ScIT
August 19, 2019, 12:29pm
#2
Can you try to run v-add-letsencrypt-user admin and post the result? Sounds like a invalid email address has entered for admin user.
Wibol
August 19, 2019, 3:22pm
#3
~# v-add-letsencrypt-user admin
The pointed domain and admin mail TLD is “.eu”. Can it be that?
ScIT
August 19, 2019, 3:34pm
#4
not really, the email needs just to be a valid one. I just tested v-add-letsencrypt-user admin on one of our test system, all worked properly. I’ll check with the team if someone would have time to look in your system.
Wibol
August 20, 2019, 5:20pm
#5
As I said, I did a “Rebuild All”. Today I created the admin email account and found this message:
Cron [email protected] sudo /usr/local/hestia/bin/v-update-sys-hestia-all
W: Failed to fetch https://apt.hestiacp.com/dists/stretch/InRelease Could not resolve host: apt.hestiacp.com
I don’t know if it can be related.
ScIT
August 20, 2019, 5:41pm
#6
It sounds that you have a dns issue. Can you check if the outbound connection is working (ping google.ch)? Also do you use openvz?
Wibol
August 21, 2019, 3:05pm
#7
I don’t know if my vps uses openvz, but a couple of days ago HestiaCP worked perfectly on it. You’re right. “ping google.es” does not respond:
ping google.es
ping: google.es: Temporary failure in name resolution
After checking it, I have done several times:
Installed Debian 9 on my VPS again and “ping google.es” works.
Upgraded the system and “ping google.es” works.
Installed HestiaCP and “ping google.es” DON’T works.
Installed HestiaCP without upgrade and “ping google.es” DON’T works.
Logout and login and “ping google.es” DON’T works.
Reboot and “ping google.es” DON’T works.
Pointed a domain from another registrar and “ping google.es” DON’T works.
Changed system hostname and PTR register and “ping google.es” DON’T works.
I can’t think what else to do.
Wibol
August 21, 2019, 4:21pm
#8
Installing Ubuntu 18.04 all works fine. I continue to investigate.
Wibol
August 21, 2019, 7:29pm
#9
Finally a solution: the time zone must be established and restarted the server before installing HestiaCP on Debian 9 .
During package upgrade:
exim4/oldstable,oldstable 4.89-2+deb9u5 all [upgradable from: 4.89-2+deb9u4]
exim4-base/oldstable,oldstable 4.89-2+deb9u5 amd64 [upgradable from: 4.89-2+deb9u4]
exim4-config/oldstable,oldstable 4.89-2+deb9u5 all [upgradable from: 4.89-2+deb9u4]
exim4-daemon-light/oldstable,oldstable 4.89-2+deb9u5 amd64 [upgradable from: 4.89-2+deb9u4]
linux-image-4.9.0-9-amd64/oldstable,oldstable 4.9.168-1+deb9u5 amd64 [upgradable from: 4.9.168-1+deb9u3]
patch/oldstable,oldstable 2.7.5-1+deb9u2 amd64 [upgradable from: 2.7.5-1+deb9u1]
tzdata/oldstable-updates,oldstable-updates 2019b-0+deb9u1 all [upgradable from: 2019a-0+deb9u1]
Appears the next message:
Current default time zone: ‘Europe/Berlin’
Local time is now: Wed Aug 21 21:20:40 CEST 2019.
Universal Time is now: Wed Aug 21 19:20:40 UTC 2019.
Run ‘dpkg-reconfigure tzdata’ if you wish to change it.
Running dpkg-reconfigure tzdata
, setting a time zone and restarting the server before installing HestiaCP, everything works properly.
The funny thing is that without installing the updates, it is also necessary to perform this procedure.
ScIT
August 22, 2019, 6:06am
#10
Hi @Wibol
That’s a interresting catch, never had such issues on my installation. I’m glad you found a solution that worked for you!
I will mark your answer as solution, please let us know if you need anything.
Wibol
August 22, 2019, 10:49am
#11
Today I created a DNS zone, several websites and email accounts and everything works perfectly.
Thank you very much for your time, great work and excellent support. I had never seen such fluid communication between developers and users.
