I assume (from previous comments by the devs) that email services are not the main focus of HestiaCP development, but have you considered using Dovecot (LMTP or LDA) for local delivery ?
Thank you for your kind remark. I had already found v-add-domain. but I was looking for something like Virtualmin’s create-domain – Virtualmin (check its functionality)
I haven’t used Exim4 before (in production), so I don’t know about possible advantages and disadvantages of letting Exim handle local delivery.
But I would like to check with others more knowledgeable whether using Dovecot LMTP might be a better option (for e.g. security, performance and features like sieve filter).
Or maybe changing local delivery from Exim to Dovecot would break existing functionality, which would make this whole discussion moot.
While looking for ways to improve HestiaCP’s mail subsystem, I noticed that SpamAssassin spamd runs as root:
root@myserver:~# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 170648 6468 ? Ss 2021 9:53 /sbin/init
root 38 0.0 0.1 83540 38824 ? Ss 2021 5:35 /lib/systemd/systemd-journald
root 361 0.0 0.0 102124 10076 ? Ss 2021 27:28 /usr/bin/perl -T -w /usr/sbin/spamd -d --pidfile=/var/run/spamd.pid --create-prefs --max-children 5 --helper-home-dir
root 404 0.0 0.0 102124 6052 ? S 2021 0:12 spamd child
root 405 0.0 0.0 102124 6712 ? S 2021 0:11 spamd child
clamav 407 0.0 3.7 1462456 1220068 ? Ssl 2021 13:33 /usr/sbin/clamd --foreground=true
Debian-+ 660 0.0 0.0 33560 7440 ? Ss 2021 0:03 /usr/sbin/exim4 -bd -q30m
www-data 2678 0.0 0.0 53500 5660 ? S Jan15 0:01 nginx: worker process
www-data 2679 0.0 0.0 53500 4036 ? S Jan15 0:00 nginx: worker process
There exists a system user “debian-spamd” with shell access but it isn’t used by default. The spamd (perl) daemon binds to tcp/783 where Exim4 connects.
At first thought, it seems that HestiaCP security on Debian 11 hosts can be improved by having spamd run as an unprivileged user (e.g. debian-spamd). For this we would need to have spamd bind to a higher port (e.g. tcp/1783)
By changing /etc/default/spamassassin accordingly e.g. OPTIONS="-u debian-spamd -p 1783 --create-prefs --max-children 5 --helper-home-dir"
I will also have to check if there are differences with previous supported Debian releases (9 and 10) and how SA is configured under Ubuntu.
As with everything else, improvements are always welcome and needed. The main problem is time. There is not enough time to improve everything at once. So we always need to make compromises and prioritize what we need to do first.
There are some improvements that get higher priority than others. That does not mean that your proposal is not good. It might be that it gets lower priority because of other more important things.
Let me bring an example. We all know the IPv4 shortage is real and will get even worse in the future. Maybe some hosts will stop offering IPv4 VPS or charge a much higher price (like Hetzner who raised some IPv4 prices the start of 2022 and I’m sure they’re not the only ones). So, it makes more sense to give priority to IPv6 implementation than improving mail subsystem.
TLDR: Every suggestion is welcome. Just don’t be disappointed if it doesn’t get any immediate attention or priority. But feel free to work on it. So when the time is right we will be many steps ahead
Another option would be to use Dovecot system-wide sieve filters to move X-Spam-Status: Yes mails to the Junk/Spam folder (instead of changing the Subject to *** SPAM ***). The only downside of this approach would be that users using POP3 instead of IMAP wouldn’t get those mails dumped in Junk.
I don’t see a big problem, with rejecting mails with super-high spam score (>10) as long as you do it properly during SMTP-time (and not with a DSN after accepting it) . Score >10 is either unquestionably spam or a misconfigured mailserver (e.g. SPF).
It’s not trivial. There are many different ways to invoke spamc to learn spam/ham. Based on a quick Google search, most online tutorials use postfix and invoke spamc from master.cf
I made a git repo of configs, scripts and installer for spam ham learning by user moving email to from junk folder. The installer isn’t perfect. Need a few.manual changes after. But most of the work is done if someone wants to check it out make some improvements go ahead. It’s a good startingroung.
