/etc/passwd
USERNAME:x:1003:1003:[email protected] :/home/username:/usr/sbin/jailbash nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
and the jail is running.
USERNAME 1 0.0 0.0 3360 144 ? S 16:42 0:00 jailbash --ro-bind /usr /usr --ro-bind /lib /lib --ro-bind-try /lib64 /lib64 --tmpfs /usr/lib/modules --tmpfs /usr/lib/systemd --ro-bind /bin /bin --ro-bind /sbin /sbin --dir /var --dir /tmp --symlink ../tmp var/tmp --proc /proc --dev /dev --bind /home/USERNAME /home/USERNAME --ro-bind-try /etc/profile /etc/profile --ro-bind-try /etc/alternatives /etc/alternatives --ro-bind-try /etc/localtime /etc/localtime --ro-bind-try /etc/ld.so.cache /etc/ld.so.cache --ro-bind-try /etc/resolv.conf /etc/resolv.conf --ro-bind-try /etc/hosts /etc/hosts --ro-bind-try /etc/nsswitch.conf /etc/nsswitch.conf --ro-bind-try /etc/ssl /etc/ssl --ro-bind-try /etc/pki /etc/pki --ro-bind-try /etc/manpath.config /etc/manpath.config --bind-try /run/mysqld/mysqld.sock /run/mysqld/mysqld.sock --chdir /home/USERNAME --unshare-all --share-net --die-with-parent --dir /run/user/1003 --setenv XDG_RUNTIME_DIR /run/user/1003 --setenv PS1 USERNAME$ --file 11 /etc/passwd --file 12 /etc/group /bin/bash -l
USERNAME 14 0.0 0.0 6700 2236 ? S+ 16:47 0:00 grep jailbash
rjd22
February 6, 2025, 3:52pm
22
That is odd, then the /var directory should be almost empty and /backup should not be linked. Something is going wrong but I don’t know what might be happening.
What OS are you running on, and is bwrap (bubblewrap) correctly installed?
Edit: are you testing this on sftp? I just checked and it looks like somehow sftp is circumvented. Does ssh work correctly for you?
Debian 12.9
Yes, it was with SFTP, tried only with SSH and cant enter the above metioned folders or edit/open files. So SSH is working normally.
rjd22
February 6, 2025, 4:07pm
24
Thank you for testing. So if I understand right the SSH is working correctly under jailbash but SFTP is not.
I will make a patch to make sure that SFTP is also jailed when jailbash is enabled.
rjd22
February 6, 2025, 7:33pm
25
I did some initial research but atm. it is not an easy fix. This is because of incompatibilities between chrooted sftp and jailed ssh.
Hopefully we can find a solution but don’t expect it fast.
np, but it would be good when it doesnt get forgotten like some other stuff
rjd22
February 7, 2025, 11:32am
27
I’ve added a PR. But could you also test this on your side for me?
If you change the following line in /etc/ssh/sshd_config
and restart ssh. Does the jailed container than work properly for sftp for you too?
Change: Subsystem sftp internal-sftp
To: Subsystem sftp /usr/lib/sftp-server
It´s working, only own home folder is visible and all important stuff not.
Mr.Yoyo
February 11, 2025, 4:50pm
29
Greetings. While I have no requirement for sshjail functionality, the system has automatically generated a directory at /srv/jail/user for the user account. Would it be safe to proceed with removing this directory?
eris
February 11, 2025, 5:01pm
30
It is also used for SFTP jail
Mr.Yoyo
February 16, 2025, 3:53pm
31
Erik sorry, English is not my native language, so I didn’t understand your answer. Can I safely delete the srv folder and disable jail in the settings?
linkp
February 16, 2025, 5:07pm
32
Mr.Yoyo:
Can I safely delete
No. Do not just delete it.
