nugie
March 7, 2021, 11:51am
#1
On Cpanel, when I am uploading the gibbon file/folder on the root directory, than after it, i am browsing the uploaded directory on browser and it working (depend on the instruction below) :
https://docs.gibbonedu.org/administrators/getting-started/installing-gibbon/
This app is requiring :
Apache 2 (with mod_rewrite)
PHP 7.0 or above (with PDO, gettext, CURL, GD, ZIP. Recommended to turn display_errors off.)
MySQL 5 (collation set to utf8_general_ci)
But when I am doing that step on HestiaCP, it won’t working . . Hope there are solution for this, thank you very much . .
Dennis
March 7, 2021, 12:49pm
#2
are you getting an error message? if it is just showing the default page, remove index.html and try again.
Dennis
March 7, 2021, 1:04pm
#4
in that case, take a look at the log files.
nugie
March 7, 2021, 1:16pm
#5
This aplication was in :
https://example.com/aplication .
So, I put the Gibbon LMS file in ‘aplication’ folder inside public_html & the wordpress was installed on main domain ‘example.com ’.
ScIT
March 7, 2021, 7:31pm
#6
We dont need to know the application you’re using. The webserver logs itself would be way more informativ about your issue. /home/user/domain/web/logs/
pluto
March 11, 2021, 5:16am
#7
If I get a 500 error the first place I look is the .htaccess file. In particular, check for php_value statements and if you find any, you may have to move them to a .user.ini file instead.
