Installing meilisearch
I was able to install meilisearch on my ubuntu instance where I have hestia already installed. It’s currently running on port 7700. How can assign a web domain that basically runs this meilisearch service on port 7700. I know I have to add a nginx configuration but is there a graceful way of doing this ?
Basically, I want to run meilisearch from a web domain that I add from hestia itself.
Are you running Nginx+Apache or only Nginx?
Nginx + Apache
You need to create a template to proxy pass requests to your meilisearch service on port 7700 (I assume the service is listening in 127.0.0.1).
A template has two files, in this case; meilisearch.tpl and meilisearch.stpl. You should create and copy them to this dir:
/usr/local/hestia/data/templates/web/nginx/
meilisearch.tpl
server {
        root        %docroot%;
                deny all;
                return 404;
        location / {
                proxy_pass http://127.0.0.1:7700;
        location /error/ {
        location /vstats/ {
meilisearch.stpl
server {
        listen      %ip%:%proxy_ssl_port% ssl;
        root        %sdocroot%;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
                deny all;
                return 404;
        location / {
                proxy_set_header Early-Data $rfc_early_data;
        location /error/ {
        location /vstats/ {
        proxy_hide_header Upgrade;
Once the files are in the right dir, create or edit your domain and add meilisearch as Proxy Template in the Advanced Options.
amazing!!! works ! there’s a typo on the extensions though, should be .tpl and .stpl . Thank a lot
Great :wink:
Yes, I mistyped them, sorry.
