redis is installed and running
and Hestia’s firewall is open for port 6379
But Redis isn’t listening on port 6379
[img=https://ibb.co/WpmLgcV[/img]
What should I check/do next?
Keep in mind that redis is not part of Hestia.
I don’t know what you want to do but usually you wouldn’t need to open port 6379 because you usually will connect to redis from localhost and those connections are by default accepted by firewall.
lsof -Pn -i:6379 -sTCP:LISTEN
systemctl status redis-server
And check redis log:
/var/log/redis/redis-server.log
make sure to update:
bind 127.0.0.1 -::1
To listen to public address
Also make sure to protect the redis server with username and password…
