I added hestia on my server. The IP is working but the domain is not. I mean the control panel domain.
But in the admin panel via ipaddress:2083 is showing ssl certificate enabled.
It was working before but when I created a new vm this happened.
Please help as soon as possible.
Did you check the logs?
disable cloudflare ssl / full etc then check the panel url 1- working >> then enable CF again and issue new ssl plus add domain wild card as trusted *.domain.ltd 2- not working, then check using IP:Port and check error log in case still not working
Resolved
Would you like to share your solution?
Promblem in SSL certificate resolved by cloudfare
