Issue logging in to hestia
Hi all,
Having issues with new install of Hestia, when I try to login just get told the information is wrong.
I did check Can't log in after install - #4 by eris and followed that, and everything is good.
I checked auth.log and find the following:
Aug 29 20:00:01 andrew CRON[11829]: pam_unix(cron:session): session opened for user admin by (uid=0)
Aug 29 20:00:01 andrew CRON[11830]: pam_unix(cron:session): session opened for user admin by (uid=0)
Aug 29 20:00:01 andrew CRON[11831]: pam_unix(cron:session): session opened for user admin by (uid=0)
Aug 29 20:00:01 andrew CRON[11831]: pam_unix(cron:session): session closed for user admin
Aug 29 20:00:01 andrew CRON[11830]: pam_unix(cron:session): session closed for user admin
Aug 29 20:00:03 andrew CRON[11829]: pam_unix(cron:session): session closed for user admin
That’s the system auth.log, you must check this auth.log:
/var/log/hestia/auth.log
You should also check these log files:
/var/log/hestia/nginx-error.log
/var/log/hestia/error.log
/var/log/hestia/system.log
Check that your disk has free space:
df -h /usr/local/hestia/
You could try to change the admin password (use single quotes to enclose the password):
v-change-user-password admin 'YourPassword'
so it seems the password I previously used wasn’t liked under this version of Hestia, I changed the password to something else and it worked.
Thanks for the help Sahsanu!
