Hi all, thank you for your great support.
I was trying to fix an old hestiacp installation cause the multi-php was not working as expected (e.g. no selection of the backnd in Server Settings).
While trying to avoid a full reinstall of the server, I thumbled in a blocking error due to the conflict between “sury” packages and this one got from the original focal repo:
https://packages.ubuntu.com/focal/libapache2-mod-rpaf
While debugging the issue I found out som any packages coming from Sury’s that… and I fail to understand why:
ii libargon2-1:amd64 0~20190702-0.1+ubuntu20.04.1+deb.sury.org+1 amd64 memory-hard hashing function - runtime library
ii libgd3:amd64 2.3.0-2+ubuntu20.04.1+deb.sury.org+1 amd64 GD Graphics Library
ii libidn2-0:amd64 2.3.0-1+ubuntu20.04.1+deb.sury.org+2 amd64 Internationalized domain names (IDNA2008/TR46) library
ii libpcre2-8-0:amd64 10.35-5+ubuntu20.04.1+deb.sury.org+1 amd64 New Perl Compatible Regular Expression Library- 8 bit runtime files
ii libpcre3:amd64 2:8.44-2+ubuntu20.04.1+deb.sury.org+1 amd64 Perl 5 Compatible Regular Expression Library - runtime files
ii libsodium23:amd64 1.0.18-1+ubuntu18.04.1+deb.sury.org+1 amd64 Network communication, cryptography and signaturing library
ii libssl-dev:amd64 1.1.1g-1+ubuntu20.04.1+deb.sury.org+1 amd64 Secure Sockets Layer toolkit - development files
ii libssl1.1:amd64 1.1.1g-1+ubuntu20.04.1+deb.sury.org+1 amd64 Secure Sockets Layer toolkit - shared libraries
ii libxml2:amd64 2.9.10+dfsg-5+ubuntu20.04.1+deb.sury.org+3 amd64 GNOME XML library
ii libzip4:amd64 1.7.3-1+ubuntu20.04.1+deb.sury.org+2 amd64 library for reading, creating, and modifying zip archives (runtime)
ii openssl 1.1.1g-1+ubuntu20.04.1+deb.sury.org+1 amd64 Secure Sockets Layer toolkit - cryptographic utility
So finally my questions:
- how to fix the dpkg error coming from the conflict between Sury packages and “libapache2-mod-rpaf” from the standard Focal repo.
- Why I see unexpected and important software coming from sury ppa repo (e.g. openssl)?
Many Thanks!
