Hello Forum,
Curious to ask if anyone created any Laravel template and it is working without issues?
You might find a few around github. However, from memory, as Laravel is just a PHP application, I think perhaps all you need to do is use Hestia’s “change root path” facility on the web domain config page. Doesn’t laravel just require you to add “public” on the end?
For Nginx + PHP-FPM There is a template
For Nginx + Apache you can use “Custom docroot”
