- I installed Hestia cp on im.photobooksgallery.com subdomain
- Created a Lets Encrypt SSL certificate for im.photobooksgallery.com, everything went well.
- I created a new user and attached the photobooksgallery.com domain to it, tried to create a certificate for it, after the download, which lasted almost 15 minutes, gives this error. I enclose the picture.
As it became clear to me after the problem in installing the Lets Encrypt certificate for the photobooksgallery.com domain. Help me solve this problem, it is very important for me.
Please share the errormessage.
Internal Server Error
Oops! Something went wrong.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Error Code: 500
Could you check /var/log/hestia/nginx-error.log
I don’t know how to do it, please show me the way
tail -f -s0.1 /var/log/hestia/nginx-error.log
And then enable ssl there should a new line be added
Please tell me where to write it, in the Terminal?
The visit the page and copy the output if you see the error message
I’m trying to access the page, it doesn’t work, it keeps loading. Sending video screenshot
https://www.dropbox.com/s/09eae1nmg3qd9xj/20221105_171431.mp4?dl=0
sudo /usr/local/hestia/bin/v-add-letsencrypt-host
и будИт Щастье )
What was it)))
I immediately entered the control panel.
Maybe you can help me?
I am attaching a short video.
https://www.dropbox.com/s/8gkeoxpzps520wm/20221105_191023.mp4?dl=0
Throw logs, without logs I can’t say anything
There is a connection timeout.
In /usr/local/hestia/nginx/conf/nginx.conf Change:
to 180s
systemctl restart hestia
And try again
No, it doesn’t work.
After I try to change SSL to my domain the whole system freezes and after that it’s useless to try, I have to reinstall the whole system.
What else can you advise me to do?Dropbox - 20221105_191023.mp4 - Simplify your life
