[NoRecords](https://letsdebug.net/panel.eve-lbs-studio.co.uk/1037221#NoRecords-Fatal)
FATAL
No valid A or AAAA records could be ultimately resolved for panel.eve-lbs-studio.co.uk. This means that Let's Encrypt would not be able to to connect to your domain to perform HTTP validation, since it would not know where to connect to.
No A or AAAA records found.
So after that I tried adding a DNS Zone in the dns section of the panel for panel.eve-lbs-studio.co.uk and I got the error:
I should probably add that there is no domain or dns record that has panel.eve-lbs-studio.co.uk apart from the domain in the admin account (no dns was created by default for the domain upon installation).
I thought I would also mention that the command “v-delete-web-domain-allow-users user domain.com” didn’t work so I reinstalled from a snapshot and unchecked the option Enforce subdomain ownership in the configure server page and that worked.
I set the admin user to only access via local IP, its only me using the panel on my small home server mainly for learning purposes but I do host a couple of my websites on it.
