It shows the hostname certificate instead of the mail.domain.com certificate (which does exist tho). If I accept using the hostname certificate, mails are landing in the spam folder of recipients. If I insert the hostname as mail server in the email program instead of mail.domain.com mails don’t land in the spam folder of recipients and everything works fine.
I’ve made a fresh installation of hestiacp 1.4.7 on clean debian 10 minimal and only ran this command: v-add-letsencrypt-host
I already had SSL enabled for the domain. I disabled and re-enabled it, getting a nginx restart error because of missing SSL cert files for the domain. I was stuck there also getting this error using the CLI:
After that, the mail seems to work properly, but unfortunately webmail didn’t work (showed only success page) it was set to roundcube in admin panel and disabling and re-enabling it over the admin panel didn’t resolve the problem.
