"Manual Action Required [IMPORTANT]" message after update to 1.8.1
after update from v1.7.8 to v1.8.1. I received this message in the confirmation email:
The upgrade script has generated additional notifications, which must be heeded urgently:
To enable the “Enhanced and Optimized TLS” feature, we must update the NGINX configuration file (/etc/nginx/nginx.conf).
But for unknown reason or you edited it, may not be fully apply all the changes in this upgrade.
Please follow the default configuration file to sync it:
/usr/local/hestia/install/deb/nginx/nginx.conf
Backed up configuration file:
/root/hst_backups/140720230543/conf/nginx/nginx.conf
Learn more:
[Feature] Enhanced and Optimized TLS by myrevery · Pull Request #3555 · hestiacp/hestiacp · GitHub
About TLS 1.3 0-RTT anti-replay for NGINX
If you use custom templates, please update them (.stpl) to apply this protection.*
Follow the usage or other default templates:
/etc/nginx/conf.d/0rtt-anti-replay.conf
Learn more:
[Feature] TLS 1.3 0-RTT with replay protection by myrevery · Pull Request #3692 · hestiacp/hestiacp · GitHub
OS: Ubuntu 20.04
Should I be worried about something? What should I do to resolve this issue?
Thank you!
