hi all,
how many sites could I host on a lightsail server 1cpu with 1gb ram?
thanks-
hi all,
thanks-
That depends on the site itself, how many visitors, which application, etc. Its impossible to say.
thanks for your fast reply - very low traffic wordpress sites… maybe 20 or less clicks per month.
I have about 6 sites on it so far but it’s using about half of the ram average.
Mysql “uses” a lot of ram but it is all available if needed. Depending on your sites it should be able to handle more sites without issues…
Cache those websites and then serve them with Nginx.
You will have great performance without mysql consumption.
thank you all.
