Here is the message I have after the upgrade to v1.4.14:
The upgrade script has generated additional notifications, which must be heeded urgently:
Warning: Please check your network config!
During this update a network compatibility issues has been detected. Both /etc/network/interfaces and /etc/netplan/60-hestia.yaml exists. This can lead to issues after a system reboot. Please review your network configuration.
cat /etc/network/interfaces
# ifupdown has been replaced by netplan(5) on this system. See
# /etc/netplan for current configuration.
# To re-enable ifupdown on this system, you can run:
# sudo apt install ifupdown
So, I shloud ignore this file, or rename it to somethings.BAK ?
