HI, i migrate my old vestacp server to vps hestiacp, but with this error y my 2 laravel websites
Error log:
public_html/.htaccess: Invalid command ‘server’, perhaps misspelled or defined by a module not included in the server configuration
Second site:
[proxy_fcgi:error] Got error 'PHP message: PHP Warning: require(): open_basedir restriction in effect
Im newby, i will apreciate your help, thanks
eris
2
Check your .htaccess file maybe some modules are not loaded also hestia uses php-fpm instead modphp
You need to disable openbase dir with a custom template
https://docs.hestiacp.com/admin_docs/web.html#how-can-i-change-settings-for-a-specific-domain
Can you help me?, i will apreciate it, please if you can send me a private message, thanks
