Would it be possible to use custom paths (web root) as a fixed template for all webs (customer)?
The point is I would like to migrate from i-mscp to hestiacp if possible …
The source paths of i-mscp should remain available:
You will run into a lot of permissions issues and so on. I would probally not try it. Also hestia saves domains / subdomains in a different structure so you have to create separate configs for each websites.
All. We current use a totally different structure… Custom docroot will not work as the folder is outside the users “directory” and so on… Manual migration is probally faster…
I guess I’ll start with an empty server and let the customers do it themselves … there are also Joomla and PrestShop and other applications …
Wordpress should work without further ado, but there are some WP plugins that also save the paths independently
thank you - that should work!
everything started with the monstrous whmcs pricing plans for lifetime license owner and the i-mscp project seems to be dead now … means a lot of migration work has to be done
