If I need to change the configuration of the /etc/bind/named.conf file, what would be the best way to do it?
If modifications are made to the file to include a directive to a specific zone (for example, allow-transfer), hestiacp adds again with each upgrade an additional line (zone “domain.tld” {type master; file “/home/usrxx/conf/dns/domain.tld.db”;} that generates errors when loading the zone, because its definition is duplicated.
How to avoid that hestiacp recognizes the modifications of the /etc/bind/named.conf file and does not add that line if the zone is already defined?
Ok, thank you very much. And I’m sorry but I had not read the documentation regarding version 1.7.0 and DNSSEC.
From now on, the modifications are then made on /etc/bind/named.options.
