Need help with api key and permissions
I’m seeking help on how to obtain the api key and secret for hestiacp. I attempted to use the command v-add-access-key account1 '', but it fails because account1 is a user and not an admin. When I try to assign permissions like v-add-access-key account1 v-add-web-domain-ssl,v-add-web-domain, it also doesn’t work, indicating that those commands do not exist.I want to avoid granting admin commands to account1, but I need this user to have the ability to create and delete domains or generate certificates. Any guidance on how to properly set this up would be greatly appreciated. Thank you!
Check this:
