hello
i need little guide. im running a apache web server and nginx reverse proxy
i want to install a script which is only support nginx … possible to install it on my serveR ? if yes can u please guide me how to setup …
note: i want to use nginx only for 1 domain other domain should run apache
please help me about it
yunli
January 22, 2025, 5:15pm
2
The idea is really unique. You can modify the relevant configuration. You must be very familiar with the working principle of the hestia system.
Why not… just tweak your Nginx Config to use PHP-FPM. Once you get it working, make it as a template and apply it. I do it with so many sites on a mixed Apache + Nginx server
Just read the template system doc.
