All of a sudden after an update i am seeing the following errors
There are some errors regarding your setup.
Your data directory and files are probably accessible from the internet. The .htaccess file is not working. It is strongly recommended that you configure your web server so that the data directory is no longer accessible, or move the data directory outside the web server document root.
Your webserver does not serve
.mjs
files using the JavaScript MIME type. This will break some apps by preventing browsers from executing the JavaScript files. You should configure your webserver to serve.mjs
files with either thetext/javascript
orapplication/javascript
MIME type. -
Your web server is not properly set up to resolve
.well-known
URLs, failed on:/.well-known/caldav
For more details see the documentation.
using the stock stpl and tpl from the php-fpm templates
