Nginix Webp - Does not generate images using the Imagick PHP extension library
Hello everyone on the forum and a sincere thanks to the developers and the software community!
I have a problem with generating for PrestaShop images in Webp format via is_themecore module (Thmes Falcon) (GitHub - Oksydan/is_themecore: Falcon theme core module.)
As a rule webp is generated, but only for logos and brand logos. The problem is with generating webp for product images. Therefore, my question is whether the .tpl and .stpl file is configured correctly
Could someone take a look at the following files. Thanks in advance for your help :slight_smile:
NewFile.stpl:
server {
        listen      %ip%:%web_ssl_port% ssl;
        root        %sdocroot%;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
        location = /favicon.ico {
                log_not_found off;
                access_log off;
        location = /robots.txt {
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        # Force pdf files to be downloaded
        location ~* \.pdf$ {
                add_header Content-Disposition Attachment;
                add_header X-Content-Type-Options nosniff;
        # Force files in upload directory to be downloaded
        location ~ ^/upload/ {
        # [REQUIRED EDIT IF MULTILANG]
        # rewrite ^/fr$ /fr/ redirect;
        # rewrite ^/fr/(.*) /$1;
        #WebP support
        location ~ ^/(\d)(-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$1$2$3.webp /img/p/$1/$1$2$3.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$1$2$3.webp;
        location ~ ^/(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$1$2$3$4.webp /img/p/$1/$2/$1$2$3$4.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$1$2$3$4.webp;
        location ~ ^/(\d)(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$3/$1$2$3$4$5.webp /img/p/$1/$2/$3/$1$2$3$4$5.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$3/$1$2$3$4$5.webp;
        location ~ ^/(\d)(\d)(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$3/$4/$1$2$3$4$5$6.webp /img/p/$1/$2/$3/$4/$1$2$3$4$5$6.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$3/$4/$1$2$3$4$5$6.webp;
        location ~ ^/(\d)(\d)(\d)(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.webp /img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.webp;
        location ~ ^/(\d)(\d)(\d)(\d)(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.webp /img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.webp;
        location ~ ^/(\d)(\d)(\d)(\d)(\d)(\d)(\d)(\-[_a-zA-Z0-9-]*)?(-[0-9]+)?/.+\.webp$ {
                try_files /img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.webp /img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.webp /modules/is_themecore/webp.php?source=$document_root/img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.webp;
        location ~ ^/c/([0-9]+)(\-[\.*_a-zA-Z0-9-]*)(-[0-9]+)?/.+\.webp$ {
                try_files /img/c/$1$2$3.webp /img/c/$1$2$3.webp /modules/is_themecore/webp.php?source=$document_root/img/c/$1$2$3.webp;
                try_files /img/c/$1$2.webp /img/c/$1$2.webp /modules/is_themecore/webp.php?source=$document_root/img/c/$1$2.webp;
        location ~ ^/(.*)\.webp$ {
                try_files /$1.webp /$1.webp /modules/is_themecore/webp.php?source=$document_root/$1.webp;
        #Images
         rewrite ^/(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$1$2.jpg last;
         rewrite ^/(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$1$2$3.jpg last;
         rewrite ^/(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$1$2$3$4.jpg last;
         rewrite ^/(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$4/$1$2$3$4$5.jpg last;
         rewrite ^/(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6.jpg last;
         rewrite ^/(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7.jpg last;
         rewrite ^/(\d)(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8.jpg last;
         rewrite ^/(\d)(\d)(\d)(\d)(\d)(\d)(\d)(\d)(-[\w-]+)?/.+\.jpg$ /img/p/$1/$2/$3/$4/$5/$6/$7/$8/$1$2$3$4$5$6$7$8$9.jpg last;
         rewrite ^/c/([\w.-]+)/.+\.jpg$ /img/c/$1.jpg last;
        # AlphaImageLoader for IE and fancybox
        rewrite ^images_ie/?([^/]+)\.(jpe?g|png|webp|gif)$ js/jquery/plugins/fancybox/images/$1.$2 last;
        # Web service API
        rewrite ^/api/?(.*)$ /webservice/dispatcher.php?url=$1 last;
        # Installation sandbox
        rewrite ^(/install(?:-dev)?/sandbox)/(.*) /$1/test.php last;
        # Source code directories
        location ~ ^/(app|bin|cache|classes|config|controllers|docs|localization|override|src|tests|tools|translations|travis-scripts|vendor|var)/ {
                deny all;
                return 404;
        # vendor in modules directory
        location ~ ^/modules/.*/vendor/ {
                deny all;
                return 404;
        # Prevent exposing other sensitive files
        location ~ \.(yml|log|tpl|twig|sass)$ {
                deny all;
                return 404;
        # Prevent injection of php files
        location /upload {
                location ~ \.php$ {
                        deny all;
                return 404;
        location /img {
                location ~ \.php$ {
                        deny all;
                return 404;
         location / {
                        expires 30d;
                location ~ [^/]\.php(/|$) {
                        try_files $fastcgi_script_name /index.php$uri&$args =404;
                        fastcgi_index index.php;
                        fastcgi_split_path_info ^(.+\.php)(/.+)$;
                        fastcgi_pass %backend_lsnr%;
        error_page 403 /error/404.html;
        error_page 404 /index.php?controller=404;
        error_page 500 502 503 504 /error/50x.html;
        location /error/ {
        location /vstats/ {
        proxy_hide_header Upgrade;
NewFile.tpl
server {
        listen      %ip%:%web_port%;
        root        %docroot%;
                log_not_found off;
                access_log off;
                allow all;
                log_not_found off;
                access_log off;
                deny all;
                return 404;
        # WebP support
        #Images
        # Web service API
                deny all;
                return 404;
                deny all;
                return 404;
                deny all;
                return 404;
        location /upload {
                location ~ \.php$ {
                        deny all;
                        return 404;
        location /img {
                location ~ \.php$ {
                        deny all;
                        return 404;
        location / {
                        expires 30d;
        location /error/ {
        location /vstats/ {
The module seems to work fine shows the source as webp (but the file is not physically there, error 404). As I mentioned earlier, only the log file and Brands are generated.
Delving deeper into the topic, I read that the cause may be a problem with Imagemagick binary files - not available
My question is how to add the binaries to make them visible to the home/{user}/web/{domain_name}/public_html page
Thanks for any suggestions
