nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/conf.d/domains/crm.--.com.ssl.conf:5
nginx: [warn] the "ssl" directive is deprecated, use the "listen ... ssl" directive instead in /etc/nginx/conf.d/domains/publitv.---.com.ssl.conf:5
nginx: configuration file /etc/nginx/nginx.conf test is successful```
Those 2 subdomains have a Reverse Proxy in NGINX.
I have Debian 11 and HestiaCP installed with NGINX only.
I have created again the SSL of the different subdomains.
Thank you very much for the time.
