I do not know what happens but my dns does not detect the domain.
I have everything configured and there is no way that my dns are public to use them.
I create the Glue Records in my domain hosting, I insert the dns but it does not detect the servers, it is as if they do not exist …
I have everything created correctly and I don’t know what to do …
I have the two NS created pointing to the ip and the two A Records with ns1.xxxx.xxx
I have created a new package in hestia putting the new servers and the SOA appears fine as well.
I’ve been with this for 24 hours and I don’t know what to do
Thanks in advance…
PS: I have already configured another domain and it works perfectly with this one I don’t know what happens … maybe I forgot a step …
the only thing i see is this in the bind log
i have check and this log is correct, not is error because in my other server is working and show same log… i dont know why not work the dns…
Wibol
July 24, 2021, 7:52am
#4
You should not use IPv6 because HestiaCP does not yet support it. It will even cause problems with LetsEncrypt.
The step you might have forgotten is to use the “Child-DNS” template for your domain.
I was using the default “as in another server that I use the same and if it works” I have changed it to child but the dns still does not work, it is like something is blocking it or it is not coming out where it should.
But I have everything set up in the registers …
I’ve been a whole day and I don’t know what to do the truth.
eris
July 24, 2021, 8:18am
#6
Hestia currently does not support ipv6 it is currently in development but it takes a lot more time
but I do not understand why you decide ipv6 … I have simply installed hestia as I have on the other server and I have done the same procedure.
On the other server it works perfectly and not on this one.
What do I have to do then?
i have read about the ipv6 and i have set the -4 i think is correct, but not working too…
I have already solved it, the problem was that being a .es domain, the propagation takes longer than normal.
Hestia worked perfectly thank you all!
system
closed
August 23, 2021, 6:31pm
#10
