PHP vulnerability
I am getting the same issue, seems to stem from a cloud cdn stale copy of the repository. can anyone help get round this?
+1 for this.
Is anyone able to confirm that hashes are correct. I guess we can probably tell apt to ignore the hash missmatch if we are happy that it’s actually correct?
Hashes of received file:
  • SHA512:b1a34b225508e5a742194fc6bc52fa235625e9b7bd790f4890c19d0ccb9e297bd5905f57dcd0d2e5bf7879ab4351caac752b440e47ff9ae065784653f331ebdd
  • SHA256:a50cc1bd86ed8ac841c9c72d5e1f699c4f7005c8ff6728bb28d6158394ba770c
  • SHA1:18ec7b4266d279aacbb1244f75b171035341e80a [weak]
  • MD5Sum:3111dcc1ef753d672a9de25cbee04a75 [weak]
  • Filesize:6325 [weak]
    Last modification reported: Thu, 22 Oct 2026 05:57:57 +0000
    Release file created at: Thu, 22 Oct 2026 09:07:33 +0000
ed: this is for https://apt.hestiacp.com/dists/noble/main/binary-amd64/Packages.gz
ed2: Still worth running the update I guess as everything else will get updated just not hestia, then disable the hestia service (as recommended above) until this, hopefully temporary, issue resolves.
Did you also try @eris script in another post? Call it update.sh:
#!/usr/bin/env bash
set -euo pipefail
apt-get update
apt-get install -y lsb-release ca-certificates curl gnupg
codename="$(lsb_release -sc)"
arch="$(dpkg --print-architecture)"
# Remove any old ondrej/sury source files
grep -rl ondrej /etc/apt/sources.list.d 2>/dev/null | xargs -r rm -f
# Fetch the signing key first
curl -fsSL https://packages.sury.org/php/apt.gpg | gpg --dearmor -o /usr/share/keyrings/sury-keyring.gpg
# Add the repository
echo "deb [arch=${arch} signed-by=/usr/share/keyrings/sury-keyring.gpg] https://packages.sury.org/php/ ${codename} main" \
  > /etc/apt/sources.list.d/php.list
apt-get update
I just purged cloudflare cache, please try again, packages should be delivered fine now.
That has solved it thanks very much, to confirm after running apt-get update && apt-get upgrade nothing else is needed.
As @eris suggested, migrate to sury’s new repository is a good idea:
#!/usr/bin/env bash
set -euo pipefail
apt-get update
apt-get update
But the old repository also ships the new packages, so apt update && apt upgrade (or apt dist-upgrade for new kernels) is all you need to do now, after that, the servers are back safe.
This didn’t help me
I’ve been sitting here all day waiting and checking for this update. I can’t figure out why it’s not available for Ubuntu 26.04 on ARM; the latest version I can see is 8.5.11. Does anyone know anything about this?
Yes, Sury has slow serial pipeline and 8.5.11 version on Arm will be the last one so in about two days.
“Monitoring the current build: amd64 uploads ran from 08:37 to 13:33 UTC on 21 Oct (all 12 series × 6 releases, finished before the 14:00 UTC PHP release). The first ARM uploads landed at 13:43 UTC. As of 01:00 UTC on 22 Oct, 19 of roughly 140 ARM builds are done; php5.6/7.0/7.1/7.2/7.3/7.4/8.0 have been running since the start, php8.3 and php8.4 started their ARM runs at about 18:30 UTC on 21 Oct, and php8.1/8.2/8.5 have not started yet. At ~5 h per step and 12 steps per series, a series finishes roughly 2.5 days after it starts, so the php8.4 arm64 builds should land somewhere between 22 Oct ~04:00 UTC and 24 Oct ~11:00 UTC depending on where each release falls in that job’s order, and php8.5 likely a day later once it gets a slot.”
Ditto, thanks @Raphael that’s working for me too now.
Can I just confirm;
Should everyone run this or just a specific subset of users?
When will hestiacp-php be patched and will it automatically update our hestiacp or do we need to do something manually?
you anyway need to upgrade your servers php versions, so run apt update && apt upgrade as suggested in this thread.
if we run apt update && apt upgrade that will patch our hestiacp-php?
yes, as written in this thread.
I was able to move everything to PHP 8.5.12 this morning (TZ Europe), my local PHP and all the ones in my containers, and didn’t face any “server unavailable” (501 or 503). It seems that once the US goes to bed, it looks like the repositories are not under heavy load anymore :slight_smile:
Ubuntu users that run Jammy / Noble. Debian and Resolute already run on deb.sury.org
Awesome thanks for confirming Eris.
Just in case anyone knows their version number but not the codenames. Ubuntu 22.04 (Jammy) and 24.04 (Noble) do not need to run the script that has been posted a couple of times.
I have 3 VPS servers running Ubuntu 20.04, each with several websites. I read in the PHP Update thread that a package was being prepared for that version.
Now I’ve come back and there’s no mention of it at all, and I see that “All supported releases are ready.”
Does that mean Ubuntu 20.04 is left out?
Yes, at least according to Ondrej’s repo. They no longer support that version.
@eris will also build an hestia-php package for Ubuntu 20.04 (focal). This means the Control Panel’s PHP vulnerability will be fixed, but your websites running PHP will still be vulnerable.
You should upgrade to a supported version of Ubuntu.
