After a global update to 1.6.5 from 1.5* version, the phpmyadmin package was not updated higher than the version (4:4.9.5+dfsg1-2). I manually uploaded the new phpmyadmin 5.2 with git and now the v-delete-sys-pma-sso and v-add-sys-pma-sso functions do not work
any ideas how to get the right version of phpmyadmin from the global service pack?
root@cp:~# sh script.sh
script.sh: 9: source: not found
script.sh: 11: source: not found
script.sh: 12: source: not found
To remove phpMyAdmin you will need use the root password. Password can be found in /usr/local/hestia/conf/mysql.conf
Would you like to continue? [y/n]script.sh: 19: read: arg count
script.sh: 26: [[: not found
Use bash
bash /usr/local/hestia/install/upgrade/manual/migrate_phpmyadmin.sh
root@cp:~# bash /usr/local/hestia/install/upgrade/manual/migrate_phpmyadmin.sh
Would you like to continue? [y/n]y
Error: PMA Single Sign On already disabled
[ * ] Backing up old configuration files…
[ * ] Marking phpmyadmin as held in apt…
phpmyadmin уже помечен как зафиксированный.
[ * ] Removing old folders…
[ * ] Creating new folders…
[ * ] Installing phpMyAdmin version v5.2.0…
[ * ] Creating localhost configuration…
[ * ] Dropping database (could throw an error if successful)…
[ * ] Creating new user…
[ * ] Creating new database…
Error: SSO has been installed before to reenable it please run v-delete-sys-pma-sso first
Please don’t just copy and paste message output - provide atleast a question, all is stated there.
root@cp:~# v-delete-sys-pma-sso
We tried to execute the command that you specified and we get the result sent in the previous message.
