Hi. from a newb
I install hestiacp with oracle and Cloudflare CDN and put some websites there.
I notice that I cannot connect to PHPmyadmin. It just won’t connect.
How can I solve this issue? I try so many things and I don’t know what to do :(((
Hi. from a newb
I see that when I put off the cloudflare CDN to no SSL its work.
What is the thing that I need to setup that SSL is not working specificaly to PHPMYADMIN?
Make sure to enable ssl first in Hestia before enabling ssl in Cloudflare to full or strict
Ok.
But now how to solve it?
Disable proxy for now and enable ssl in the settings then you can enable it again
