Hello, maybe this was discussed somewhere, but I did not find it. I edited the package, and set the number of backups to 0, I lost the backup block in the user. I thought well, and set it to 1, then 2, but the block did not appear back). Tell me who knows where else to look or what to do so that he comes back. In the config, too, I did not see anything interfering with it.
API=‘no’
API_SYSTEM=‘2’
BACKEND_PORT=‘2083’
BACKUP_GZIP=‘9’
BACKUP_MODE=‘zstd’
BACKUP_SYSTEM=‘local’
CRON_SYSTEM=‘cron’
DB_PMA_ALIAS=‘phpmyadmin’
DB_SYSTEM=‘mysql’
DEBUG_MODE=‘false’
DISABLE_IP_CHECK=‘no’
DISK_QUOTA=‘no’
DNS_CLUSTER_SYSTEM=‘hestia’
ENFORCE_SUBDOMAIN_OWNERSHIP=‘yes’
FILE_MANAGER=‘true’
FIREWALL_EXTENSION=‘fail2ban’
FIREWALL_SYSTEM=‘iptables’
INACTIVE_SESSION_TIMEOUT=‘600’
LANGUAGE=‘ru’
LOGIN_STYLE=‘default’
MAIL_SYSTEM=‘exim4’
PHPMYADMIN_KEY=‘’
PLUGIN_APP_INSTALLER=‘true’
POLICY_CSRF_STRICTNESS=‘1’
POLICY_SYSTEM_ENABLE_BACON=‘false’
POLICY_SYSTEM_HIDE_ADMIN=‘no’
POLICY_SYSTEM_HIDE_SERVICES=‘no’
POLICY_SYSTEM_PASSWORD_RESET=‘yes’
POLICY_SYSTEM_PROTECTED_ADMIN=‘yes’
POLICY_USER_CHANGE_THEME=‘yes’
POLICY_USER_DELETE_LOGS=‘yes’
POLICY_USER_EDIT_DETAILS=‘yes’
POLICY_USER_EDIT_DNS_TEMPLATES=‘yes’
POLICY_USER_EDIT_WEB_TEMPLATES=‘yes’
POLICY_USER_VIEW_LOGS=‘yes’
POLICY_USER_VIEW_SUSPENDED=‘false’
RELEASE_BRANCH=‘release’
SERVER_SMTP_ADDR=‘’
SERVER_SMTP_HOST=‘’
SERVER_SMTP_PASSWD=‘’
SERVER_SMTP_PORT=‘’
SERVER_SMTP_SECURITY=‘’
SERVER_SMTP_USER=‘’
SMTP_RELAY_HOST=‘smtp.vivaldi.net’
SMTP_RELAY_PORT=‘587’
SMTP_RELAY=‘true’
SMTP_RELAY_USER=‘’
STATS_SYSTEM=‘awstats’
THEME=‘dark’
UPDATE_HOSTNAME_SSL=‘yes’
UPGRADE_SEND_EMAIL_LOG=‘false’
UPGRADE_SEND_EMAIL=‘true’
USE_SERVER_SMTP=‘false’
VERSION=‘1.7.8’
WEB_BACKEND=‘php-fpm’
WEBMAIL_ALIAS=‘’
WEBMAIL_SYSTEM=‘’
WEB_PORT=‘80’
WEB_SSL=‘openssl’
WEB_SSL_PORT=‘443’
WEB_SYSTEM=‘nginx’
