Hello. After update Hestia cant start.
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up hestia-nginx (1.19.10) ...
Job for hestia.service failed because the control process exited with error code.
See "systemctl status hestia.service" and "journalctl -xe" for details.
invoke-rc.d: initscript hestia, action "start" failed.
Active: failed (Result: exit-code) since Thu 2021-10-07 12:37:05 MSK; 6ms ago
Process: 191091 ExecStart=/etc/init.d/hestia start (code=exited, status=2)
Oct 07 12:37:05 xxxxxxx.site systemd[1]: Starting LSB: starts the hestia control panel...
Oct 07 12:37:05 xxxxxxx.site hestia[191091]: * Starting hestia-nginx hestia-nginx
Oct 07 12:37:05 xxxxxxx.site hestia[191095]: start-stop-daemon: unable to stat /usr/local/hestia/nginx/sbin/hestia-nginx (No such file or directory)
Oct 07 12:37:05 xxxxxxx.site systemd[1]: hestia.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Oct 07 12:37:05 xxxxxxx.site systemd[1]: hestia.service: Failed with result 'exit-code'.
Oct 07 12:37:05 xxxxxxx.site systemd[1]: Failed to start LSB: starts the hestia control panel.
cat: /usr/local/hestia/nginx/conf/nginx.conf: No such file or directory
sed: can't read /usr/local/hestia/nginx/conf/nginx.conf: No such file or directory
Error: ERROR: Restart of hestia failed.
dpkg: error processing package hestia-nginx (--configure):
installed hestia-nginx package post-installation script subprocess returned error exit status 1
hestia-nginx
