Problem to install imunify360 with hestiacp
Hello, I am transferring here the problems I have had with the latest versions of imunify360 in hestiacp. The particular problem is related to the imunify360 webshield module (uses modsecurity), and the cause is the apache rpaf module that seems to come by default in the hestiacp apache installation but is a module that has been abandoned since 2014. The technicians’ solution was indicated below (disable rpaf and use remoteip):
[email protected]:~$ apachectl -M |grep rpaf
[email protected]:~$ apachectl -M |grep rem
 remoteip_module (shared)
# commented out rpaf module
vi /etc/apache2/mods-enabled/rpaf.load
# return back remoteip config
mv /etc/apache2/mods-enabled/remoteip.conf_bck /etc/apache2/mods-enabled/remoteip.conf
I mention this in case this information can help other colleagues.
Greetings
