Problem with Docker application proxy
Hey guys, for me Hesita is running on port 2083 and I just launched a docker container that listens on 0.0.0.0:8083 on the server. In Hestia I am using both Apache2 and Nginx as proxy and web server.
I have a web domain configured in Hestia which I’d like to point to the docker container. To do that I used the cp.tpl and cp.stpl templates and modified them a little bit.
However, as a result I get this weird blob of an image instead of the container web ui. Can someone help me figure out what the issue is? Here is the template file I am using
dockerapp.tpl
server {
        error_log   /var/log/%web_system%/domains/%domain%.error.log error;
                deny all;
                return 404;
        location / {
                proxy_pass http://%ip%:8083;
                location ~* ^.+\.(%proxy_extensions%)$ {
                        try_files  $uri @fallback;
                        root       %docroot%;
                        expires    max;
        location @fallback {
                proxy_pass http://%ip%:%web_port%;
        location /error/ {
dockerapp.stpl
  GNU nano 6.2        vault.stpl
server {
        listen      %ip%:%proxy_ssl_port% ssl;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
                deny all;
                return 404;
        location / {
                        root       %sdocroot%;
                        expires    max;
        location /error/ {
        proxy_hide_header Upgrade;
You can’t use port 8083 unless you have changed the default port
Literally the first line of my post. :expressionless:
Also, I should clarify I can access the docker application on http://ip:8083. which makes me believe it’s just a proxy issue.
Any update on the issue?
