Hi all!
There is exim4.96 Everything works properly, no problems. Unexpectedly, the task was set: to block letters with attachments like - rar, zip, tar …, etc., in order to avoid running some encryptor by users. OK. I googled until my eyes popped and, according to poor knowledge, did the following: The .forward filter file contains:
# Exim filter
if $message_body contains "qqq" # понятное дело тут будут указаны расширения архивов
then
deliver "[email protected]_mydomain.com"
pipe "/home/папка/blockedmail.sh ${local_part}@${domain} ${message_id}"
seen finish
endif
The script file itself:
#!/bin/sh
echo "Your email has been blocked due to violation of our terms of service.\n[$1]\nMessage ID:[$2]\nSender...\n" \
| mail -s "You have a new mail in quarantine!" "$1"
As a result, if the letter contains the content “qqq”, it redirects this letter to the [email protected]mydomain.com mailbox and sends the necessary message to the recipient. Now I can’t understand why the filter only works with one local mailbox (eg bigchlen@mydomain.com)? If I send it to another mailbox like vaskaspizdaskas@_mydomain.com -
then the filter does not work and immediately sends it to Vasily with the content “qqq”. I understand that the problem is that hestiacp only works under one user. How to make the filter work for all users?
