I usually only use the default Debian / Ubuntu images via my provider and works like a charm
If some provider use a “Hesita” from an image you not be able to modify according your needs for example remove apache2 or install sieve.
For Installing Hestia we only require to have curl and wget available most cases they should be present have see on minimal images that they need to installed first. (Very rare)
