Hi
Im not developer , I haired a guy from upwork to setup my server , He recommended the Hestia , I did enable 2Fa for loging , I think there was issue now cant access the cpanel , any help ? or anyone can help me to recover ?
Do you have shell access?
sudo v-delete-user-2fa admin
Hi Thanks for your reply , I should have as I have dedicated server. So able to access
Oke login into your server.
If your username is root
If you are logging in as a different username you will need to use sudo v-delete-user-2fa admin
As I said Im not developer , Could you plz able to help me , if i provide u details ,
Currently we do not have any paid support from hestia itself, you may get another user out of the community which will help - but running a own server without any deep knowledge isnt a good idea at all. Maybe switch over to a shared hosting?
You don’t need a developer to run some cli commands on a server. But if you are not comfortable with that you will have a difficult time managing a dedicated server and implementing everything that goes into that, like backups and disaster recovery, security, monitoring hw/sw, automating tasks and so on.
No-mater what software you end up running on the server things will brake at some point and somebody with sysadmin expertise (you or someone else) will have to fix it.
