Maruus
April 13, 2022, 4:21pm
1
Hello, sorry for my eanglish.
I have a problem with installing hestiacp, there is still this problem, I changed the resorvename and nothing helps. Debian 10 system.
PHP Notice: Unable able to load required libaries. Please run v-add-sys-phpmailer in command line in /usr/local/hestia/web/inc/main.php on line 9 Unable able to load required libaries. Please run v-add-sys-phpmailer in command line
while the vesta installs without any problems.
eris
April 13, 2022, 4:38pm
2
Maruus:
v-add-sys-phpmailer
Run /usr/local/hestia/bin/v-add-sys-phpmailer
Maruus
April 13, 2022, 5:08pm
3
curl: (6) Could not resolve host: composer.github.io Error: Download signature
As you can see it does not install packages …
eris
April 14, 2022, 5:23am
4
You need to check why your server isn’t able to resolve external servers/DNS.
Looks like a DNS issue
Maruus
April 14, 2022, 1:06pm
5
It’s a bit weird because the server shows fine, even changed to 8.8.8.8.
Edit: on another vps no problem.
looks like its a problem with your vps, good that it works on another.
system
Closed
May 15, 2022, 4:19am
7
