Can you please tell me in which configuration files there may be an error? or maybe there is a command how to set the default configuration.
Roundcube not working, error 500.
This is what I am see in the logs:
[Fri Feb 04 10:50:32.696417 2022] [php7:warn] [pid 80198] [client 79.184.1.139:0] PHP Warning: Unknown: failed to open stream: Operation not permitted in Unknown on line 0
[Fri Feb 04 10:50:32.696427 2022] [php7:error] [pid 80198] [client 79.184.1.139:0] PHP Fatal error: Unknown: Failed opening required '/var/lib/roundcube/index.php' (include_path='.:/usr/share/php') in Unknown on line 0
Maybe there is some command that will reinstall the system while saving the data.
I have tried this command.
apt update && apt install --reinstall hestia
Thanks a lot for any idea.
