Running HestiaCP through the gre tunnel
Hello, I want to ask if it is possible to make the panel work through gre tunnel and everything worked through gre, so that people bind the domain to the IP from the gre tunnel, etc.
The tunnel? You mean?
yeah, i mean tunnel
I haven’t tried it before. Hestia currently only supports domain name access and does not support direct IP access!
You mean to install hestia locally and let local services run through a tunnel?
If I understand you correctly, then yes, I need everything to work on 1 server, but all the services were available through a tunnel hosted on some purchased vps.
Is your server running public or internal? The domain name is not required for internal use
