Thu Feb 9 05:05:30 2023 -> SelfCheck: Database status OK.
Thu Feb 9 05:40:00 2023 -> Waiting for all threads to finish
Thu Feb 9 05:40:22 2023 -> Shutting down the main socket.
Thu Feb 9 05:40:22 2023 -> Pid file removed.
Thu Feb 9 05:40:22 2023 -> --- Stopped at Thu Feb 9 05:40:22 2023
Thu Feb 9 05:40:22 2023 -> Closing the main socket.
Thu Feb 9 05:40:22 2023 -> Socket file removed.
Thu Feb 9 09:51:23 2023 -> +++ Started at Thu Feb 9 09:51:23 2023
Thu Feb 9 09:51:23 2023 -> Received 0 file descriptor(s) from systemd.
Thu Feb 9 09:51:23 2023 -> clamd daemon 0.103.6 (OS: linux-gnu, ARCH: x86_64, CPU: x86_64)
Thu Feb 9 09:51:23 2023 -> Log file size limited to 4294967295 bytes.
Thu Feb 9 09:51:23 2023 -> Reading databases from /var/lib/clamav
Thu Feb 9 09:51:23 2023 -> Not loading PUA signatures.
Thu Feb 9 09:51:23 2023 -> Bytecode: Security mode set to "TrustSigned".
Thu Feb 9 09:51:43 2023 -> Loaded 8651924 signatures.
Thu Feb 9 09:51:47 2023 -> LOCAL: Unix socket file /var/run/clamav/clamd.ctl
Thu Feb 9 09:51:47 2023 -> LOCAL: Setting connection queue length to 15
Thu Feb 9 09:51:47 2023 -> Limits: Global time limit set to 120000 milliseconds.
Thu Feb 9 09:51:47 2023 -> Limits: Global size limit set to 104857600 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: File size limit set to 26214400 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: Recursion level limit set to 16.
Thu Feb 9 09:51:47 2023 -> Limits: Files limit set to 10000.
Thu Feb 9 09:51:47 2023 -> Limits: Core-dump limit is 0.
Thu Feb 9 09:51:47 2023 -> Limits: MaxEmbeddedPE limit set to 10485760 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: MaxHTMLNormalize limit set to 10485760 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: MaxHTMLNoTags limit set to 2097152 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: MaxScriptNormalize limit set to 5242880 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: MaxZipTypeRcg limit set to 1048576 bytes.
Thu Feb 9 09:51:47 2023 -> Limits: MaxPartitions limit set to 50.
Thu Feb 9 09:51:47 2023 -> Limits: MaxIconsPE limit set to 100.
Thu Feb 9 09:51:47 2023 -> Limits: MaxRecHWP3 limit set to 16.
Thu Feb 9 09:51:47 2023 -> Limits: PCREMatchLimit limit set to 10000.
Thu Feb 9 09:51:47 2023 -> Limits: PCRERecMatchLimit limit set to 5000.
Thu Feb 9 09:51:47 2023 -> Limits: PCREMaxFileSize limit set to 26214400.
Thu Feb 9 09:51:47 2023 -> Archive support enabled.
Thu Feb 9 09:51:47 2023 -> AlertExceedsMax heuristic detection disabled.
Thu Feb 9 09:51:47 2023 -> Heuristic alerts enabled.
Thu Feb 9 09:51:47 2023 -> Portable Executable support enabled.
Thu Feb 9 09:51:47 2023 -> ELF support enabled.
Thu Feb 9 09:51:47 2023 -> Mail files support enabled.
Thu Feb 9 09:51:47 2023 -> OLE2 support enabled.
Thu Feb 9 09:51:47 2023 -> PDF support enabled.
Thu Feb 9 09:51:47 2023 -> SWF support enabled.
Thu Feb 9 09:51:47 2023 -> HTML support enabled.
Thu Feb 9 09:51:47 2023 -> XMLDOCS support enabled.
Thu Feb 9 09:51:47 2023 -> HWP3 support enabled.
Thu Feb 9 09:51:47 2023 -> Self checking every 3600 seconds.
Thu Feb 9 09:51:47 2023 -> Listening daemon: PID: 474
Thu Feb 9 09:51:47 2023 -> MaxQueue set to: 100
