Helllo,
after reboot I have this on my Hestia panel: Screenshot by Lightshot
But both mysql and clamav running in server (see output below). What’s wrong and how to fix it in panel?
Tried to restart services via panel; stop via ssh and start via panel again, nothing helped.
# systemctl status mysqld
● mariadb.service - MariaDB 10.5.12 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─migrated-from-my.cnf-settings.conf
Active: active (running) since Tue 2021-08-31 09:30:26 EEST; 13min ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 3074 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 3075 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 3077 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_POSITION=$VA
Process: 3142 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 3144 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 3125 (mariadbd)
Status: "Taking your SQL requests now..."
Tasks: 24 (limit: 4915)
Memory: 325.0M
CGroup: /system.slice/mariadb.service
└─3125 /usr/sbin/mariadbd
# systemctl status clamav-daemon
● clamav-daemon.service - Clam AntiVirus userspace daemon
Loaded: loaded (/lib/systemd/system/clamav-daemon.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/clamav-daemon.service.d
└─extend.conf
Active: active (running) since Tue 2021-08-31 09:20:57 EEST; 25min ago
Docs: man:clamd(8)
man:clamd.conf(5)
https://www.clamav.net/documents/
Process: 14750 ExecStartPre=/bin/mkdir /run/clamav (code=exited, status=1/FAILURE)
Process: 14751 ExecStartPre=/bin/chown clamav /run/clamav (code=exited, status=0/SUCCESS)
Main PID: 14752 (clamd)
Tasks: 2 (limit: 4915)
Memory: 1.4G
CGroup: /system.slice/clamav-daemon.service
└─14752 /usr/sbin/clamd --foreground=true
