Setting Mail Limits has no effect
I am having a bit of trouble with rate limits on Exim. By default, it seems to limit everybody to 200 Mails per hour. As I have one domain sending a Newsletter, I set the limit for that particular domain to 9999. Unfortunately, this did have no effect and I got mails rejected mentioning I exceeded the limit by sending 200.5 mails / hour.
Then I tried to set the enhanced rate globally (exim-conf-template) to 4000 per hour. This also had no effect and I still got the rejected mails.
Also, changing the value in /etc/exim4/limit.conf directly did not change the behaviour.
What am I missing?
The sending software is a PHP application (ACYMailing), which worked before on another server. There is no rate limiting within that application.
Any suggestion welcome.
Cheers,
Stefan
Hestia Control Panel: v1.9.4
Operating System: Ubuntu 24.04 (x86_64)
Limits used in limit.conf or in limit per mail domain is only valid for SMTP sessions used by authenticated users. For PHP scripts it uses a hardcoded limit of 200.
What did you modify in /etc/exim4/exim4.conf.template?
The part for PHP scripts is this one:
acl_not_smtp:
  deny    message       = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
  ratelimit             = 200 / 1h / $authenticated_id
  warn    ratelimit     = 100 / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
  accept
Remember to backup the file /etc/exim4/exim4.conf.template and restart Exim after the changes.
systemctl restart exim4
Ok. Not sure, whether the Mailer uses SMTP. Maybe not.
Yes, that’s the part I modified. Changing 200 to 4000 and 100 to 2000. I am quite sure to have restarted exim, but I will recheck.
Thanks,
Stefan
Ok, the changes now seem to have had an effect. Strange. I modified the template via HestaCP where it has this “restart” checkbox. But it seems it did not have the desired effect.
Thanks and all the best,
Stefan
Glad you solved it :wink:
Hestia internally restarts exim4 service like this:
systemctl reload-or-restart exim4
As Exim supports reload, it is reloaded instead of restarted and seems Exim needs to be restarted to apply the new hardcoded ratelimit.
Hey,
Might be good to have a second checkbox then. :smirking_face:
Cheers,
Stefan
