I strongly suggest to NOT manualy edit the files inside of the conf directory, expect you know what you’re doing - otherwise they will got overwritten within the next hestia update.
Please do a copy of your template (you’ll find them in $HESTIA/data/templates/web/) and adjust the relating part.
