Smtp sender more 100 mails
hi
i use acymailing for emailing and i configure it for send 100 mails in 10 minutes with 5 secondes between each mail
but i see exim4 send only 10-20 mails
i search and see exim4 is limited
how i can send faster
i try to add smtp_accept_queue_per_connection=100 in /etc/exim4/exim4.conf.template
but nothing
can you help me please
thanks
stéphan
There is a setting in the user account mail server. I just noticed it when editing the mail server to add an SSL certificate to the mail server. By fault, it is set for 100 per hour, add a zero to the end to raise it to 1000.
