Something is changing 'listen' directive on nginx.conf of the Hestia
ip -d -j link show | jq .
    "ifindex": 1,
    "ifname": "lo",
    "flags": [
      "LOOPBACK",
      "UP",
      "LOWER_UP"
    "mtu": 65536,
    "qdisc": "noqueue",
    "operstate": "UNKNOWN",
    "linkmode": "DEFAULT",
    "group": "default",
    "txqlen": 1000,
    "link_type": "loopback",
    "address": "00:00:00:00:00:00",
    "broadcast": "00:00:00:00:00:00",
    "promiscuity": 0,
    "allmulti": 0,
    "min_mtu": 0,
    "max_mtu": 0,
    "inet6_addr_gen_mode": "eui64",
    "num_tx_queues": 1,
    "num_rx_queues": 1,
    "gso_max_size": 65536,
    "gso_max_segs": 65535,
    "tso_max_size": 524280,
    "tso_max_segs": 65535,
    "gro_max_size": 65536
    "ifindex": 2,
    "ifname": "eno1np0",
    "flags": [
      "BROADCAST",
      "MULTICAST",
      "SLAVE",
      "UP",
      "LOWER_UP"
    "mtu": 1500,
    "qdisc": "mq",
    "master": "bond0",
    "operstate": "UP",
    "group": "default",
    "txqlen": 1000,
    "link_type": "ether",
    "address": "92:dc:4b:f7:5a:8a",
    "broadcast": "ff:ff:ff:ff:ff:ff",
    "permaddr": "ac:1f:6b:56:7f:2e",
    "promiscuity": 0,
    "allmulti": 0,
    "min_mtu": 68,
    "max_mtu": 9702,
    "linkinfo": {
      "info_slave_kind": "bond",
      "info_slave_data": {
        "state": "ACTIVE",
        "mii_status": "UP",
        "link_failure_count": 1,
        "perm_hwaddr": "ac:1f:6b:56:7f:2e",
        "queue_id": 0,
        "prio": 0,
        "ad_aggregator_id": 1,
        "ad_actor_oper_port_state": 63,
        "ad_actor_oper_port_state_str": [
          "active",
          "short_timeout",
          "aggregating",
          "in_sync",
          "collecting",
          "distributing"
        "ad_partner_oper_port_state": 61,
        "ad_partner_oper_port_state_str": [
          "active",
          "aggregating",
          "in_sync",
          "collecting",
          "distributing"
    "inet6_addr_gen_mode": "none",
    "num_tx_queues": 16,
    "num_rx_queues": 16,
    "tso_max_size": 65536,
    "gro_max_size": 65536,
    "phys_port_name": "p0",
    "phys_port_id": "ac1f6b567f2e",
    "phys_switch_id": "2e7f56ffff6b1fac",
    "parentbus": "pci",
    "parentdev": "0000:1b:00.0",
    "vfinfo_list": []
    "ifindex": 3,
    "ifname": "eno2np1",
    "flags": [
      "BROADCAST",
      "MULTICAST",
      "SLAVE",
      "UP",
      "LOWER_UP"
    "mtu": 1500,
    "qdisc": "mq",
    "master": "bond0",
    "operstate": "UP",
    "group": "default",
    "txqlen": 1000,
    "permaddr": "ac:1f:6b:56:7f:2f",
    "promiscuity": 0,
    "allmulti": 0,
    "min_mtu": 68,
    "max_mtu": 9702,
    "linkinfo": {
        "state": "ACTIVE",
        "mii_status": "UP",
        "perm_hwaddr": "ac:1f:6b:56:7f:2f",
        "queue_id": 0,
        "prio": 0,
          "active",
          "short_timeout",
          "aggregating",
          "in_sync",
          "collecting",
          "distributing"
          "active",
          "aggregating",
          "in_sync",
          "collecting",
          "distributing"
    "phys_port_name": "p1",
    "phys_port_id": "ac1f6b567f2f",
    "parentbus": "pci",
    "parentdev": "0000:1b:00.1",
    "vfinfo_list": []
    "ifindex": 4,
    "ifname": "bond0",
    "flags": [
      "BROADCAST",
      "MULTICAST",
      "MASTER",
      "UP",
      "LOWER_UP"
    "mtu": 1500,
    "qdisc": "noqueue",
    "operstate": "UP",
    "group": "default",
    "txqlen": 1000,
    "promiscuity": 0,
    "allmulti": 0,
    "min_mtu": 68,
    "max_mtu": 65535,
    "linkinfo": {
      "info_kind": "bond",
      "info_data": {
        "mode": "802.3ad",
        "miimon": 100,
        "updelay": 0,
        "downdelay": 0,
        "peer_notify_delay": 0,
        "use_carrier": 1,
        "arp_interval": 0,
        "arp_missed_max": 2,
        "arp_validate": null,
        "arp_all_targets": "any",
        "primary_reselect": "always",
        "fail_over_mac": "none",
        "xmit_hash_policy": "layer2",
        "resend_igmp": 1,
        "num_peer_notif": 1,
        "all_slaves_active": 0,
        "min_links": 0,
        "lp_interval": 1,
        "packets_per_slave": 1,
        "ad_lacp_active": "on",
        "ad_lacp_rate": "fast",
        "ad_select": "stable",
        "ad_info": {
          "aggregator": 1,
          "num_ports": 2,
          "actor_key": 15,
          "partner_key": 15,
          "partner_mac": "2a:99:3a:7d:61:ed"
        "ad_actor_sys_prio": 65535,
        "ad_user_port_key": 0,
        "ad_actor_system": "00:00:00:00:00:00",
        "tlb_dynamic_lb": 1
I don’t see any IPs in this output.
Ok, I see the problem and it’s in a previous command:
ip -d -j link show | jq -r '.[] | if .link_type == "loopback" // .linkinfo.info_kind then empty else .ifname end'
That command doesn’t found your bond interface.
Could you please test this command and check that you see the 3 interfaces?
ip -d -j link show | jq -r '.[] | if .link_type == "loopback" then empty elif .linkinfo.info_kind == "bond" then .ifname elif .linkinfo.info_kind then empty else .ifname end'
If tou see the 3 interfaces, edit this file /usr/local/hestia/func/syshealth.sh and in this function syshealth_adapt_hestia_nginx_listen_ports replace this:
        physical_nics="$(ip -d -j link show | jq -r '.[] | if .link_type == "loopback" // .linkinfo.info_kind then empty else .ifname end')"
With this:
        physical_nics="$(ip -d -j link show | jq -r '.[] | if .link_type == "loopback" then empty elif .linkinfo.info_kind == "bond" then .ifname elif .linkinfo.info_kind then empty else .ifname end')"
Save the file and try again apt upgrade
Yes, it shows all 3 interfaces:
eno1np0
eno2np1
bond0
Now replace the file as I said and try apt upgrade.
Yes, now after the upgrade, hestia service is launched:
systemctl status hestia
     Active: active (running) since Thu 2026-10-01 14:41:58 UTC; 23s ago
    Process: 4153566 ExecStart=/etc/init.d/hestia start (code=exited, status=0/SUCCESS)
      Tasks: 3 (limit: 76647)
     Memory: 10.7M (peak: 15.0M)
        CPU: 72ms
     CGroup: /system.slice/hestia.service
             ├─4153571 "nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx"
             ├─4153572 "nginx: worker process"
             └─4153574 "php-fpm: master process (/usr/local/hestia/php/etc/php-fpm.conf)"
Oct 01 14:41:58 systemd[1]: Starting hestia.service - LSB: starts the hestia control panel...
Oct 01 14:41:58 hestia[4153566]:  * Starting hestia-nginx hestia-nginx
Oct 01 14:41:58 hestia[4153566]:    ...done.
Oct 01 14:41:58 hestia[4153566]:  * Starting hestia-php hestia-php
Oct 01 14:41:58 systemd[1]: Started hestia.service - LSB: starts the hestia control panel.
netstat -anp | grep :8778
tcp        0      0 0.0.0.0:8778            0.0.0.0:*               LISTEN      4153571/nginx: mast
Ok, I’ve created this PR to support bond interfaces in hestia-nginx port detection:
