Yeah, same IP pool, bro
Itβs at version 4.96
Make sure to download:
and name it /etc/exim4/exim4.conf.template
Hi @eris
I have just tried it but after that it release the new issue ![]()
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
[email protected]
Unrouteable address
Reporting-MTA: dns; vn1.kaovm.com
Action: failed
Final-Recipient: rfc822;[email protected]
Status: 5.0.0
Subject Hello World
From [email protected]
To [email protected]
Date Today 09:12
This is test email from KAOVM Server.
Outgoing Email
it looks like an issue with DNS resolution
So what I need to do now, eris
I comply whole admin staff instruction but the result does not change ![]()
Hi @eris @sahsanu,
Today I check exim4 service and it shows failed with exit-code, bro ![]()
systemctl status exim4.service
Γ exim4.service - LSB: exim Mail Transport Agent
Loaded: loaded (/etc/init.d/exim4; generated)
Active: failed (Result: exit-code) since Wed 2024-09-18 11:51:28 +07; 3min 15s ago
Process: 978 ExecStart=/etc/init.d/exim4 start (code=exited, status=1/FAILURE)
CPU: 248ms
Sep 18 11:51:27 myserver.example.com systemd[1]: Starting exim4.service - LSB: exim Mail Transport Agent...
Sep 18 11:51:28 myserver.example.com exim4[978]: Starting MTA:
Sep 18 11:51:28 myserver.example.com exim4[1424]: 2024-09-18 11:51:28 Exim configuration error in line 507 of /var/lib/exim4/config.autogenerated.tmp:
Sep 18 11:51:28 myserver.example.com exim4[1424]: Unexpected end of configuration file: .endif missing
Sep 18 11:51:28 myserver.example.com exim4[1440]: Invalid new configfile /var/lib/exim4/config.autogenerated.tmp, not installing
Sep 18 11:51:28 myserver.example.com exim4[1440]: /var/lib/exim4/config.autogenerated.tmp to /var/lib/exim4/config.autogenerated
Sep 18 11:51:28 myserver.example.com systemd[1]: exim4.service: Control process exited, code=exited, status=1/FAILURE
Sep 18 11:51:28 myserver.example.com systemd[1]: exim4.service: Failed with result 'exit-code'.
Sep 18 11:51:28 myserver.example.com systemd[1]: Failed to start exim4.service - LSB: exim Mail Transport Agent.
